SSE resistor R3 higher wattage
Ok I have not even stated assembly yet and found I made an error. For R3 I have a 10k 3W resistor, same as R14 and R24 instead of a 1W resistor. Any issue with using a 3W in R3 besides some additional bending to get it to fit? Just want to make sure I am not upping the wattage on a resistor designed to be a weak link in case something goes wrong.
