I'm working on the layout/parts ordering for my build which is slowly coming together. So far, I had planned on positioning the Power Trans and OPTs conventionally at the top/back of the chassis - i.e. Power trans in one corner, rotated 90 degrees to the OPTs. positioned side by side at the other side. My question concerns positioning the choke and supp cap.
To save size and space on the main chassis, I could build a small frame inside the enclosure, using V slot 2020 aluminum (grounded of course) and mount the choke on it below the Power trans and the supp cap laying horizontally on the frame under the OPTs.
Does anyone foresee a problem with that approach?
