Hi All,
I am working on a DSP based on ADAU1466 + SRC4392, controlled by an ESP32 through SPI interface.
My programming skills are not so great, so i where wondering if anyone have a sketch they would be willing to share with me?
Currently i have tried this code which does not seem to do the trick;
Serial response from the sketch is:
Physically checked that hardware rst pin is 3.3v, and i am can program ADAU1466 through same spi interface
Schematic for the SRC chip:
Screenshot by Lightshot
Code:
#include <Arduino.h>
#include "PCF8575.h"
#include "SPI.h"
unsigned char audioSRCCom(unsigned char address, unsigned char data, bool read = false);
void audioSRCWrite(unsigned char address, unsigned char data);
unsigned char errorCode;
#define SPI_SRC 4
#define SPI_ADAU 5
#define AUDIO_SRC_R14_INTMASK 0xF4 // CRC, parity, validity, bip encoding, and dir unlock unmasked
#define AUDIO_SRC_R18_INTMODE 0xAA // interrupt mode to level change
#define AUDIO_SRC_R19_INTMODE 0xAA
PCF8575 exp1(0x21);
PCF8575 rexp(0x22);
const SPISettings settingsA(1000000, MSBFIRST, SPI_MODE3); // Store SPI transaction information to settingsA
uint8_t audioSRCCom(unsigned char address, unsigned char data, bool read) {
uint8_t Response = 0x00; // Set response to 0
digitalWrite(SPI_SRC, LOW);
SPI.beginTransaction(settingsA);
SPI.transfer(address);
SPI.transfer(0);
SPI.transfer(data);
SPI.endTransaction();
digitalWrite(SPI_SRC, HIGH);
if (!read) return Response; // End if only write session
delay(1);
Response = SPI.transfer(0xFF);
return Response;
void src_statuses () {
Serial.print("SRC Interupt Status: ");
Serial.println(audioSRCCom(0x02, 0x01, true));
Serial.print("SRC Ready Status: ");
Serial.println(audioSRCCom(0x0A, 0x10, true));
Serial.print("SRC Ratio Status: ");
Serial.println(audioSRCCom(0x0A, 0x20, true));
void initiate_src4392 () {
src_statuses();
audioSRCCom(0x7f, 0x00); // Initial write to page register, selecting page 0
audioSRCCom(0x01, 0x80); // Software reset
audioSRCCom(0x03, 0x31); // Port A format I2S, slave mode, src->porta
audioSRCCom(0x04, 0x01); // Port A clock to MCLK/256 (48k)
audioSRCCom(0x05, 0x41); // Port B format I2S, slave mode, mute output (port is not used)
audioSRCCom(0x06, 0x01); // Port B clock to MCLK/256 (48k)
audioSRCCom(0x08, 0x31); // Bypass Mux RX1, AESMUX BYMUX, LDMUX BPMUX, Enable AES and TX
audioSRCCom(0x0D, 0x08); // DIR reference clock = MCLK
audioSRCCom(0x0E, 0x08); // Automatic DIR-mute for loss of lock
audioSRCCom(0x0F, 0x12); // Registers 0F, 10 and 11; PLL1 configuration. Values from datasheet: P=1, J=8, D=0
audioSRCCom(0x10, 0); // Registers 0F, 10 and 11; PLL1 configuration. Values from datasheet: P=1, J=8, D=0
audioSRCCom(0x11, 0); // Registers 0F, 10 and 11; PLL1 configuration. Values from datasheet: P=1, J=8, D=0
audioSRCCom(0x16, 0xF4); // CRC, parity, validity, bip encoding, and dir unlock unmasked
audioSRCCom(0x18, 0xAA); // interrupt mode to level change
audioSRCCom(0x19, 0xAA); // interrupt mode to level change
audioSRCCom(0x2d, 0x42); // Port B as input, MCLK as Ref, Mute Disabled, Volume tracking leftch.
audioSRCCom(0x30, 0x07); // Set left channel volume -3.5dB
audioSRCCom(0x31, 0x07); // Set right channel volume -3.5dB
audioSRCCom(0x01, 0x3f); // Activates the chip, remove soft RST, Enable all.
delay(10);
src_statuses();
void setup() {
delay(1000); // 1 second startup delay
Serial.begin(9600); // Initialize the USB serial port for debug
pinMode(SPI_SRC, OUTPUT); // src4392 CS pin
pinMode(SPI_ADAU, OUTPUT); // adau1466 CS pin
digitalWrite(SPI_SRC, HIGH); // Pull SRC4392 CS pin HIGH
digitalWrite(SPI_ADAU, HIGH); // Pull ADAU1466 CS pin HIGH
exp1.pinMode(P5, OUTPUT); // ADAU1466 Reset pin
exp1.pinMode(P6, OUTPUT); // SRC4392 Reset pin - H/W Linked to ADAU1466 Reset, if ADAU1466 RST is low, SRC4392 will be low for atleast 300ms after ADAU1466 turns high
exp1.begin();
exp1.digitalWrite(P5, HIGH);
exp1.digitalWrite(P6, HIGH);
delay(10);
SPI.begin();
void loop() {
initiate_src4392();
delay(5000);
SRC Interupt Status: 0
SRC Ready Status: 0
SRC Ratio Status: 0
SRC Ready Status: 0
SRC Ratio Status: 0
I have programmed SRC4392 before, but with Arduino. Maybe could help some, but not clear on the problem you are having. Can you read and write SRC4392 registers? Some other problem?
Hi Mark,
Problem is that the chip does not seem to respond. I have a leds for indication of the chips RDY, INT and LOCK pins, which seems that none of these ever gets activated. So, my question would be if i am correctly addressing the chip through SPI interface.
Actually got one step closer now. I have LOCK signal when attaching AES interface, however i also have Interupt signal and still no ready signal. Responses from Serial interface is the same, so i guess there is something wrong in my code.. 🙄
Can you write the registers while the SRC4392 is in software reset? I've checked what I do in my Verilog code and the only suspicious difference I found is that I first switch off the software reset and then write the registers.
parameter [511:0] src4392spidata = 512'h0100390031004100000000000000081821CB02000000000000000000000000000000000000000000000000000000010400000000000000000000000000000000;
// These bits have to be shifted into the SRC4392 from high to low!
// Address 01, value 39: Sample rate converter on, DIR off, DIT off,
// port B on, port A on, general enable on, reset off.
// address 03, value 31: port A in slave mode, outputs signal from SRC,
// sound not muted, 24 bits I2S
// address 05, value 41: port B in slave mode, output off, 24 bits I2S
// addresses 0B and 0C, value 00: interrupts off
// address 0D, value 08: RXCLK set to MCLK, input 0 to DIR. Hardly relevant,
// as I don't use the DIR anyway.
// address 0E, value 18: DIR muted when DIR gets unlocked,
// clock of PLL2 not divided, RXCKO-output off, PLL2 free running
// when not locked
// addresses 0F...11, values 21CB02: PLL1 to P = 2, J = 7, D = 2818, as
// recommended for a 27 MHz reference clock
// address 1B, value 00: GPO1 off
// address 1C, value 00: GPO2 off
// address 1D, value 00: GPO3 off
// address 1E, value 00: GPO4 off
// adresses 1F...2C: read only, so written values get ignored.
// address 2D, value 01: SRC converts data from port B, uses the MCLK as
// reference, sound not muted, left and right volumes separately controllable
// address 2E, value 04: de-emphasis off, no decimation filtering, FIFO
// length of 64 words
// address 2F, value 00: 24 bits output words
// adresses 30 and 31, values 00: output attenuators set to 0 dB
// Rest is nonsense.
// when not locked
