SR1DK - Audison Monoblock drivers replacement
Amp does not produce proper class D switching even without the outputs in.
Driver board has been worked before - so condition is unknown.
I took out the outputs out of the board , they read just fine on the tester.
I've got some weird reading measuring the buffers - q24, q25, q27,q28.
DMM in diode mode -readings are between 156 - 264 depending which one i'm measuring ...i suppose they are kind-a dead. This seems odd buffers to die, but the outputs to survive.
As I can't find 2sb1236a/2sd1857a can I use 2SB649A + 2SB649A ?! Specs seems compatible ?
Schematics attached.
