Square wave testing....Cap value
Joined 2002
Most load tests with square waves seem to be 8 ohms parallel with 2 uF. I found that 8 ohm parallel 0.1uF created more problems than 2uF. Additionally 8 ohms parallel 0.01uF sometimes causes oscillation on the horizontal flat portions. Sometimes very hard to get rid of.
I also saw someone on the web say that he also found 0.1uF more problematic than 2 uF. I can't remember where that was.
What's the experience on this forum ?
Cheers.
I use 0.01uF, 0.1uf , 0.22uF , 0.47uf, 1uF, 2.2uF, 4.7uF. All film caps 250 volt rating. The 0.01 and 0.1 are 630 volt films.
Covers the whole range I guess. The 4.7uF might be a bit extreme.
Cheers.
