Hi all,
I've been thinking (always a dangerous thing) about a stack of drivers I have kicking around and pondered using them to make a TMWWWW, with a sealed Mid, and four drivers for the woofer, and having fallen in love with transmission lines have been trying to figure out if I could get away with using them in that configuration.
MJK's worksheets allow for stacking two driver's vertically, but any more then that and it stops working for the purposes of making it a transmission line. My question is, is there a reason not to use four drivers in a square, therefore not running into the problems that would normally come from stacking four drivers vertically in a MLTL. My (admittedly lacking) understanding is that as long as the centre-to-centre of the drivers fell within a certain upper wavelength limit then they would act as one driver, and wouldn't suffer from any combing effects, so in the case of a TMWWWW, where they would probably be filtered out at a max of around 300hz (wavelength of roughly 45"), there shouldn't be any issues?
I have run the idea past MJK on his yahoo group and he suggested that it is an idea that may work in a TL, but I wondered if anyone here had some input or had tried something similar in the past.
using these parameters for the 4 drivers:
F: 48hz
R: 6.3Ohm
L: 0.732mH
Bl 13.488
Sd: 480cm^2
Vas: 70.83
Qes: 0.537
Qms: 1.637
Qts: 0.404
And Geometry:
Length: 178cm
Driver distance from top: 43.5
Port from top: 160cm
Internal top and bottom area: 38cm*38cm
Stuffed about a third of the way down between driver and port with stuffing density of 0.6lb/ft^3
Radius of port: 9cm
Length of port: 8cm
I get a graph of this for the Frequency response
F: 48hz
R: 6.3Ohm
L: 0.732mH
Bl 13.488
Sd: 480cm^2
Vas: 70.83
Qes: 0.537
Qms: 1.637
Qts: 0.404
And Geometry:
Length: 178cm
Radius of port: 9cm
Length of port: 8cm
