Spreadsheet for Folded Horn Layouts...
Macro seems to work great!
E1 and E2 are the cells I choose for desired L and S4
Range("D19").Select
Range("D19").GoalSeek Goal:=0, ChangingCell:=Range("D11")
Range("D20").Select
Range("D20").GoalSeek Goal:=Range("E1"), ChangingCell:=Range("D15")
Range("D21").Select
Range("D21").GoalSeek Goal:=Range("E2"), ChangingCell:=Range("D16")
*edit* could probably be refined by eliminating .Select
First try at Macro though.
*edit2* yep it worked.
I have mine bound to Ctrl + L
Brian,
I have downloaded the post1 spreadsheet.
The sheet is not protected.
Please select the cells that the user needs to input data and protect all other cells.
I use blank (no entry) as my password so that experienced users can get in and turn off the cell protection and make modifications to the calculations/colours etc. Then re-protect after mods.
I can do that for my downloaded copy, it's the other less experienced excel users that I am thinking about.
Is post1 the latest version?
I have just found Version 1.5.0 in post58. It too is not protected.
Is there any way to approximate a dual taper TH?
With the expansion rate change in the middle?
Or at least have the expansion guide and reference points for goal seeking the right size for the middle bits.
Don't see why it shouldn't be possible to approximate that type of TH. Try using different settings for the expansion ratios and review the change in expansion using the "Horn Expansion" graph. You may have to ignore optimizing "DCheck", which is basically used to ensure smooth expansion through the entire horn.
It might be even better to find a way to use exported expansion data from HornResp in the Horn Expansion graph - I'll look into modifying the spreadsheet to do this on the weekend.
Brian,
The latest version of the spreadsheet is located at http://www.diysubwoofers.org/misc/Stepped-TH.zip. It's now protected 🙂.
Heloo Master Steele
How difficult would things be to couple the size of the fold diplsay to the actual size of the fold. I have done a couple of designs that are larger than the 70 by 70 cm and they just don't look that great all chopped up and such.
I know give Mark an inch and he takes a centimeter!
Wait a second that is 2.54 cm!
Mark
Heloo Master Steele
Mark
It should be pretty easy. You'd want to modify the properties of the graph's axes - either change the "max limit" to auto, or set it to a limit that's higher than your design's maximum width and height.
