Hi!
I'm building a tube preamp for bass, and I'm planning to build in a line trafo to get a balanced output for my power amp. However, I would also like to be able to send the signal at mic level to the stage mixer.
So my question is, will this work? My thinking is, the first resistors of the H-pad should isolate the attenuating resistor from the higher level signal and keep it intact.
(The resistor values in the H-pad are missing because I still don't know how much attenuation I'll need.)
