split power supply from two single PSUs
Hello. I have a question:
Is it possible to get split power supply by connecting two single switching power supplies as shown in the picture? And what will happen if they have slightly different voltages (+- 0.1-0.2V)? Power is required for the tda2050 amps and active filters based on the op-amps.
I am aware that it is better to use a transformer for such a project, but for a number of reasons this is not possible.
make sure they are identical units and follow the correct polarity to get that split supply, i do that all the time..
There might be some spurious effects when two supplies share the same ground line from the load chassis. The ground line might become a sense resistor for both supplies. A star ground would be needed, IMO.
