SPL limit for 2 way or 3way single point loudspeakers question
I just came accross this software which can perform a dual channel FFT with m-noise: https://opensoundmeter.com/en/ free is much cheaper than SMAART!
True, but with dynamic mics often struggling above 10kHz and below 50Hz (requiring large compensations and, in the HF, finnicky positioning), I'd opt for a large-diaphragm condenser. It's often possible to rent those from nearby studios, and the good ones will take >150dB without complaining.
Chris
You can also rent measurment mics from people like studiocare if you have a one off requirment.
how does this work for the 1" elements?
They're mounted at the throat of the horn on a 3D-printed combiner, as you'd expect. The 2" elements tap in close to the throat via semi-circular slits. From that point, the horn itself is 'just' a segmented flare with asymmetrical expansion in the vertical dimension.
Some cropped screenshots of an old Instagram post:
As great as OSM is for free, the process is still very involved. Personally I don’t think a real-time FFT tool is appropriate. It relies far too much on a visual assessment of objective parameters.
You should be in the far field of the source, so mic clipping is less of a concern if you have a field or car park nearby and can average enough to minimise the impact of wind. The bigger problem is a large enough amplifier to supply sufficient unclipped peak voltage - this is covered in the AES specification document. You need >300V — a bridged pair of Powersoft X8 channels — to drive the midrange of many larger pro audio boxes to their Lpeak…
You seem to be handy with MATLAB, so why not make a script that actually assesses sequential traces and controls the gain increase steps properly?
ah ok I'm out of date having not read the AES document and just going from the procedure here using a dual channel FFT: https://m-noise.org/procedure/ . We do have a Lab Gruppen FP 10000Q that should do 300Vpeak bridged but I will need to get a higher SPL mic to test any 'serious' speakers. Automating in MATLAB/Octave would be pretty straightforward but at the moment I'm very overloaded with other projects....
Thanks for the additional photos I think I get it now
