Help,
The simulator I have to work with is X-Spice, actually Spice 3f4 with extentions for mixed analog and digital. Its part of the PROTEL 99SE Schematic Capture and PCB Layout suite I use.
I'm looking for Spice 3f4 models for "garden variety" twin triodes and beam tetrode and pentode output tubes. The Norman Koren implementation preferably.
Actually this is an exersize in lazyness. I don't want to sit down and implement/check the models from scratch if they are already available somewhere (that is if someone has already done it).
Converting the Koren P-Spice models to Spice 3f4 is not that difficult its just a pain in the proverbial as there is no direct equivalent function in 3f4 for one of the key P-Spice functions that Koren uses.
Ian
Ian
Thanks Geek
Thanks for these models.
One other question.
I have modeled the output transformer as mutual coupled inductors.
Unfortunately there doesn't appear to be an equivalent to the P-Spice K-ALL function in 3f4 so I had to write all of the K statements separately. This seemed to work OK but was a long a labourious process in entering the model.
Any ideas / references on a better way?
Thanks again,
Ian
P.S. Notes for newbies to modeling:
1) The simulation will be exactly as good as your models - no better, no worse.
2) The best simulation of a vaccuum tube is done on the bench using a vaccuum tube.
Despite the above simulation is VERY useful as a method of avoiding basic errors.
One other question.
Thanks again,
Ian
Re: Thanks Geek
Yes. There are some excellent 3f4 transformer models with CM Student. Rob the models from there 😉
Very true. After breadboarding a modeled tube circuit, the DC voltages and currents are usually dead-on, but AC performance? That's where the experimenters know-how comes in 😉
gingertube said:I have modeled the output transformer as mutual coupled inductors.
