speed control
Hi all,
I'm trying to power my DIY TT with a Maxon motor as simple as possible.
I hooked a 1.5 V battery to motor and it goes too slow,
2 batterys giving 3.0 V is too fast
Could I just add a potentiometer to lower speed with the 3.0 V ? would it be stable? what type and make of pot should i get for best performance?
As you can see I know nothing in electronics
IK
Normally, motors for turntables are driven by regulated speed control.
Setting the voltage (or current) in the motor will only set the speed of the platter for a certain record (mass), stylus needle and arm position (outer or inner area of the record will impose different drag on the stylus and thus different braking effect on the platter).
A simple potentiometer would work (provided it can withstand the power wasted in it, several watts peak), but a voltage- or current-regulator (optionally with feedback from the motor) works better.
For starters, you could take a look into the datasheets of National Semiconductors' LM317 or LM338.
But please keep in mind that true motor drivers for turntable platters work even more sophisticated than that - and that there is no consensus on the ultimately best way to drive a platter motor.
Sek.
yeah, the 317 is a great place to start, the origin live uses a circuit similar to that to get the required voltage to spin the motor.
apparently speed will vary from the outer track to the inner track but i've heard it a couple times on a linn lp12 and it doesnt seem to be apparent.
Thanks, Looks simple even for me....
Some of the big boys do use simple no regulation controls, Galibier for example.
Would you recomend the adjustable regulated circut or the one with the improved ripple rejection (pg 15)?
Also, the scheme shows input V of 28V or more. Could I use a lower V battery?
many thanks
IK
we are considering a DC motor drive.
I see two ways to do that
1.) fixed and absolutely steady DC voltage at extremely low source impedance. Do not use a resistor for motor speed control, that will increase the change in speed as load varies.
2.) regulated voltage with speed related negative feedback.
with 1.) the motor speed will change for changes in motor loading.
with 2.) the motor speed will constantly change as the NFB repeatedly corrects errors that are attenuated in the drive belt and hopefully held near constant at the platter. I fear this method will take a lot of development.
1.) will be much simpler and I suspect audibly acceptable. A very high inertia platter will attenuate speed variations brought about by groove modulation creating extra/less drag on the recording.
A «simple» solution to the problem associated with alternative 1) could be to let the motor drive an auxiliary axle with higher friction and thus drag than the platter + pickup, this could make the variations in drag from the platter + pickup less significant than the drag from the auxiliary axle. I believe this could improve speed stability of the DC-motor, though I’m not an expert in this field.
Mvh
KJ
Ooops my time as a passive member of diYAudio.com Is over.
For DC motors the simplest best way of driving them is via a
variable voltage supply that has a negative output resistance
equal to the resistance of the motor windings.
Then essentially speed is fixed by the drive voltage = the back
emf generated by the motor with the winding losses compensated.
The current drawn at correct speed depends on the load.
🙂/sreten.
