Does anyone have access to specs on the Dali 606 drivers? 🙂
This is all the info written on the magnetlabel:
Tweeter: D26TG-47-06
06 Ohm - 703
Bass/midrange: TC18BG08-12
12 Ohm - 707
The support isn't answering any time soon it seems..
06 Ohm - 703
12 Ohm - 707
Yes, I reckoned they were Vifa.. 🙂
But I can't seem to find anything about them, so can any of you guys try? Tried searching around, but no luck.. So I was hoping you could give it a try! 😉
They are likely OEM drivers made specifically for Dali -- only Tymphany & Dali will have the specs.
dave
dave
Almost all Dali drivers are OEM VIFA drivers, however the D26TG-47-06 tweeter is very similar to the D26TG-35-06 (http://www.tymphany.com/datasheet/printview.php?id=255)
The woofer I'm afraid doesn't have a directly comparable off-the-shelf version.
Typical.. ^^
Is there anyone on this forum that's known for having a connection to Dali? 😉
I don't want to throw these away, cause I'd rather use them in a little DIY speaker.. I have two sets of 606, and one of them are a bit shabby, so I thought I'd make use of the drivers..
But it seems it's hard to get specs on them, so I don't know what to do...
Measure them then. You should anyway if you are making a decent job of the project even if you have manufacturer parameters.
The woofer should be close to this but with a higher impedance curve.
http://www.tymphany.com/datasheet/printview.php?id=290
In Oz we get a PAE 18WG08 which is basically a TC / BC driver.
http://www.digitalmegahouse.com/peerless audio speakers.htm
Keltern said:Is there anyone on this forum that's known for having a connection to Dali? 😉
Well, I do business with Peter Lyngdorf but I'm not sure he's willing to disclose such information. I can ask at the next oppertune moment though.
richie00boy said:Measure them then. You should anyway if you are making a decent job of the project even if you have manufacturer parameters.
Well, I don't know how decent it'll be, as I haven't built speakers before.. But I'll try to make the best of it! 🙂
Sounds good! 🙂 I just hope I'll be able to make use of them.. It'd be a shame to throw them away just because someone thinks such info should remain a secret.. They're not in production anymore, so I don't see the big deal! But then again, it could just be me! 😛
- Specs on drivers anyone?
