Speakerworkshop - no enclosure plot!
Help!
I'm trying to learn how to use SW. Modelling crossover responses is fine, however I can't get my enclosure to produce a frequency response curve.
(I would have posted this on the SW forum - but appears to be down?)
I follow these steps:
1. Create an enclosure
2. Enclosure -> properties -> chamber 1 (select woofer), click ok
3. Calculate -> Sealed (select any alignment), click ok
... and graphs are "empty" (both the graph on the enclosure window as well as any individual graph)
Any help / ideas?
PS: I'm using V1.06
Thanks,
Dave.
I take it you have created a driver and added all the specs, then in the enclosure properties chamber 1 you have clicked on choose a diver to air.
I'm also using 1.06, plot comes up fine, using this sequence. Maybe you should double check that you have entered all of the driver specs.
Also I would recommend looking at unibox (excel spreadsheet) I like it better for doing simulations. I use speaker workshop for measuring the drivers but do modeling with unibox. Others may have other opinions 🙂
Regards,
Tony.
Thanks for the replies.
Yup - selected the driver in chamber 1 (as per my first post). Yup - tried Y axis automin max as well as "hard coded"
Maybe my project is stuffed up. I'll try a new "clean" project with just the driver and enclosure (forget the xover)
At least I know it *cn* be done with 1.06
Cheers and may the driving force be with you,
Dave.
