Speakers for a BEO 1600
I've come into possession of a B&O Beomaster 1600 receiver circa 1980s.
I've basically just use it as a radio, but I do think it among the most interesting and cleanest B&O designs.
See attached photo.
The photo also shows a mock up of a little project to add a pair of speakers in the same style as the Beomaster receiver.
I can manage the fabrication. It will take some careful and detailed work, but I've got lots of time during COVID.
As you can see in the attached (upper right hand photo) of the side view of the receiver, the front of the device has a 2 inch height and the back of the device has a 3.75 inch height.
I can make the width of the speakers anything I want (maybe some Fibonacci proportion) so I have flexibility in the width.
Device specifications:
Power output: 2 x 15 W RMS
Frequency Response: 30 - 25,000 Hz +/- 1 dB
Distortion: less than 1 % between 40 and 12,500 Hz
Signal-to-noise ratio: better than 50 dB
Channel separation: better than 40 dB at 1000 Hz; better than 30 dB at 10,000 Hz
Tuner
FM 87.5 - 104 MHz plus 4 fixed-tuned stations
LW 147 - 350 kHz, 2040 - 857 m
MW 520 - 1600 kHz, 578 - 188 m
SW1 1500 - 4500 kHz, 200 - 66.6 m
SW2 5.9 - 18 MHz, 49 - 16 m, with expander
Aerial: 75 ohm
Connections: DIN
Voltage: 110 - 130 - 220 - 240 V
2 pairs of speaker 4 ohms
Dimensions H x W x D: 12 x 42 x 23cm
Weight: 5.5 kg​
I'd very much appreciate recommendations for a driver that could fit in the form factor, within which I have to work.
