tda 2050 working sound ok
components tightly soldered--dual rail--16.5-0-16.5 v transformer--2200 uf/50 v 2 caps
--but----
signal cable not connected------speaker vibrating little bit
signal cable connected--------speaker vibrating little bit----but when signal cable is adjusted pushing a little bit inside in pc sound out jack---no speaker vibration
---------IS THIS NORMAL THING OR ANY PROBLEM ? ---------
--but----
am i able to explain now clearly
signal cable not connected, when i touch the speaker it is vibrating little bit
signal cable connected, when i touch the speaker vibrating little bit, but when signal cable is adjusted pushing a little bit inside in pc sound out jack, no speaker vibration
Is this normal or any problem?
