Speaker stand...
15" Dayton Quatro $75 each
MDF, screws, glue and wire - About $20 each (gonna paint in spring)
Binding posts - $10 each
MCM/Audioquest plate amp - $25 each (crossover dialed all the way down)
Shelf supports for panels - $8 each
Maggie MMG - $275 each
Spear by door for when the neighbors show up - Priceless.
Hmmm.... I made up something similar to that once.
It went something like this:
Peerless XLS @ 30hz 110dB
Adire Tumult @ 15hz 112dB
JL audio 12w7 @ 20hz 115dB
JBL GTX @ 25hz 113dB
Playing below tuning.....
Bassless
There are some notes a bass reflex cant hit. For everything else,
there's resonance
Some folks tested 'em, and the general consensus was that MCM had the Audiosource plate amps miscatalogged... I think one fellow said 100 watts into four ohms.
Works fine for me - may upgrade to a pair of the 240 watt soft clipping plate amps eventually, but then again, I have yet to hear funky noise coming, and a neighbor and I ran through some Sir Mix-a-Lot earlier...
