Hello,
So i simulated what my drivers would sound like in an enclosure and I came across something interesting... For some reason the simulation doesn't show any of the speakers passing 5000Hz, all just drop there which is very inaccurate as the FR 10 Hm's are able to go 22 000 Hz.
Drivers: 1x Visaton WS 20 e 4 ohm in a vented 39l enclosure
4x Visaton Ws Fr 10 Hm 8 ohm (2 pairs, each pair at it's own channel, drivers in single pair are wired parallel making it 4 Ohm)
These are full range drivers althought they lack bass but I have the subwoofer for that.
So anyone has any ideas?
Graph Image:
https://i.ibb.co/TtGQ3L9/image.png
SimBox Project:
Complete speaker.BPJ - Google Drive
Graph Image:
SimBox Project:
Loaded your boxsim file up and you have no frequency or impedance data for any of the drivers loaded in. Looks like you have only up input the TS parameters. If you hit the "Load driver from file" button for each driver and select the file for the speakers (these come with the install .BCH file) then it will load full frequency and impedance responses for each driver. you can then start to play around with the crossovers.
There are no files for these specific driver, atleast not in the version i downloaded.
All the files i have (image):
https://i.ibb.co/5s2dhZ3/image.png
My v2.0 of boxsim came with all of the drivers for all of the visaton speakers including the two you are using (107 speakers in total). May be worth downloading and re-installing.
Iirc I downloaded from this thread Boxsim v.2.0 launched!!
Thank you for the help, I've noticed it was a seperate download from the website however there still isn't a file for visaton WS 20 e
here's those that I got with my version of boxsim v2.0.
you will need to put them in the "chassis" directory and change the extension to .BCH
Hope this helps.
- Speaker simulation w/ BoxSim question
