I have an Onix Strata Mini speaker that is causing my NAD M3 amp to go into amp protection at high volumes. What would normally cause an amp to go into projection? The amp worked fine for years with these speakers. I've checked all the cables and connections. It is definitely being caused by my right speaker. Any suggestions would be a huge help.
Thanks,
Dan
Thanks,
Dan
Does the suspect speaker trip the other channel in the amp ?
Yes you can measure impedance if you have a meter that reads RMS voltage over a wide frequency range and a signal generator. Check my figures first...
http://www.diyaudio.com/forums/multi-way/121524-testing-speakers-impedence.html#post1488054
Yes, if I switch the cable the other channel will trip with the same speaker.
That's proof enough I guess.
I take it the speaker sounds OK in every respect... how about a mono source, is the image central.
- Speaker Protection Problem
