I'm building a PA subwoofer using an Eminence Sigma Pro-18" (see other thread), and I want to protect it with a fuse. The driver handles 500w/RMS, and the DC resistance is 6.4 ohms. There is no crossover because I am bi-amping. How can I figure out what fuse rating to use, and should it be slo-blow or fast-blow?
Thanks,
Evan
Thanks,
Evan
hehe aluminium foil. I have alot of experience with aluminium foil. It's actually depend. I ahve see case when they just didn't last a week. It depend if you push your system hard. Also playing with aluminium foil is not very reccomended. You will always have a problem when it's they foil in place.
You can also use a higher value fuse but passed a point it's going to be the speaker protecting the fuse(tweeter make excellent fast acting fuse btw
Not the ones I mean.
They look like:
<img src=http://www.elfa.se/images/ct_tnail/A10672_C.JPG>
And they are rated from 2 A and up.
//magnus
They look like:
//magnus
Evan, the best option for speaker protection is a relay. This relay protcetion has serveral advantages over fuse protection.
Disadvantages of fuses:
- Its difficult to determine the fuse rating because the speaker impedence varies with frequency and the type of enclosure.
- If an approximate fuse rating is used, it keeps blowing after a while and in many cases the speakers will die for the fuses.
Relay protection:
- Speaker is connected only when powersupply is available and this may include muting to avoid turn-on transients.
- If DC is detected it immediately disconnects the speaker from the amplifier.
Many kits are available for Speaker protection, you can try Velleman Kit K4700.
- XL.
Relay protection:
- XL.
- Speaker protection: how to fuse?
