Find this protection circuit:
http://users.otenet.gr/~athsam/protection_2_EN.htm
and like to try on it. The kyt81-122 is difficult to find so can I use a ntc thermo resistor instead. I would think of feeding R3,R2 into - input of IC1a and R1,ntc into + input of IC1a. Would that work? How are we going to test if this part works? If I am going to glue the sensor to a test heatsink and do the calibration or testing, I might never able taking it off and glue it to the working one? Can I use a pot for R3 so as to adjust the temperature for cut-off.
bigpanda said:The kyt81-122 is difficult to find so can I use a ntc thermo resistor instead. I would think of feeding R3,R2 into - input of IC1a and R1,ntc into + input of IC1a. Would that work?
Yes.
With cheap thermometer or with your fingers.
Bolt NTC on a small sheet of metal on one side. Use your soldering iron and warm up the opposite side. Put your finger on the NTC. Lift your finger up when the NTC gets too hot for you; this means that the the temperature is about 65-70C. Immediately measure NTC resistance. Use the same value for R3. Simple, right?😉
I wouldn't be in favor of this. A better idea is to use a small piece of metal bolt and a screw. Use thermal grease between the heatsink and NTC.
Yes.
Regards,
Milan
Tks Milan,
If I still can't get the kyt81-122 by end of this month, I should try using the ntc thermo-resistor.
I find this IC in Rotel RB-1090 schematic.
You can find this here: http://www.eserviceinfo.com
Mayky
Mayky
- speaker protection circuit
