I'm not sure if im in the correct form but I have a few questions about wiring speakers to change the ohms. I know that 4 (8 ohms) speakers can be wired in series to give you a 8 ohms load and in parallel to give you 2 ohms.
first question
Based on the concept of wiring 4 (8ohms) speakers in series to give an 8 ohms load, can I wire 4 (8 ohms) 2 way cabinet to get an 8 ohms load?
Also, I read online that you can wire 3 (8 ohms) speakers, 2 in series and 1 in parallel to give you a 5.3 ohms load but its not recommend to do so, instead, an (8 ohms) resistor should be used to act as a dummy speaker to make up the 4th speaker.
Second question
If i were to used a resistor to act as a dummy speaker does the resistor rms watts needs to add up to one of the speaker RMS?
first question
Second question
Yes, it doesn't matter if it's a full range, 2 way, 3 way etc.first question
What are you trying to accomplish? More info please.Also, I read online that you can wire 3 (8 ohms) speakers, 2 in series and 1 in parallel to give you a 5.3 ohms load but its not recommend to do so, instead, an (8 ohms) resistor should be used to act as a dummy speaker to make up the 4th speaker.
Yes but why?Second question
Yes but why?
Thank you for the quick response Cal.
ok, so I have 6 (8") woofer and and 2 (1") exit horn and i was planning to build 2 full range cabinet, 3 woofer and 1 horn as a fun & cheap project. But, instead in building a custom crossover I wanted to add the resistor to make up for the 4th speaker so that I can use a standard 8 ohms 2 way crossover.
Using a resistor is a waste of power and it will have to be large. Consider this: Use one woofer and one tweeter in a set of cabinets. Those we'll call those the satellites.
Make another cabinet with 4 woofers for a bass unit. Use a plate amp to run the woofer box.
or
Make two cabinets with two woofers each. This would require two plate amps, one per box.
or
Do it the right way: buy 2 extra 8 ohm speakers.
Even the worst speaker in the World is way better than any resistor.
Unless I misread, four 8 ohm speakers in series makes 32 ohms. Four 8 ohm speakers in parallel makes 2 ohms. Four 8 ohm speakers wires in series/parallel combination makes 8 ohms.
And resistors are a lot harder to hear than speakers.
When wiring speakers in series (either drivers or multi-ways) they all need to be the identical model. Otherwise you will get very strange frequency response variations.
If your 8" are PA drivers, I doubt there'll be any bass. Most are for mids.
so what's wrong with making a speaker that presents a 5.3 ohm load to the crossover(series parrallel combination) the change/shift in frequency may not be objectionable.
A "fun & cheap project"doesn't need such attention to details.
Use a 4.7uF capacitor in series with your tweeter and you're good to go!
But if you wanna go specific on that stuff, do the following:
1- Measure the drivers. You'll find several methods for that. Here's one:
Measuring Loudspeaker Driver Parameters
2- Design the Speaker box. Here's WinISD one of the best and free speaker designing programs.
LinearTeam
3- Design the Crossovers. There are several free crossover calculators on the net. winISD has some good calculator too.
LinearTeam
LinearTeam
Thanks for the info
- Live Sound
- PA Systems
- Speaker Ohms
