I am working on active crossover design for my speakers.Trying to figure out best way to take measurements.Unfortunately outside is not very quiet for measurements.
If i have to do them indoors what is the best way to get good measurements.
I had done measurements with speaker at location where its going to be in room. Microphone within 1 inch of each driver.
But when i look at impulse response its bad.
So wondering if need a different approach.
"I am working on active crossover design for my speakers." Are these finished speakers (cabinets already built) or are you still in the design stage?
If the latter, some enthusiast / semi pro pages have a section of hints and tips:
http://www.troelsgravesen.dk/measurements.htm
http://www.zaphaudio.com/setup.html
There is a lot of information on Linkwitz site regarding how he went about measuring speakers and how to design a good baffle. You'll have to dig through his postings to glean the relevant information, but it'll give good insight as to how to design speakers.
There is more to a great in-room sounding speaker than flat on-axis frequency response. SL goes into how off axis response shapes in-room power response, which is what we actually hear. After building LXmini+2's I set about building LX521 inspired OB and these are the best speaker I have heard in my room, it dose not matter where in the room I sit the sound stage never collapses into one speaker it's always radiating from behind the speakers.
I measured mine in my shed as it's big, but before I had this I measured in-room with driver 1/2 way between floor and ceiling, mic 500mm from driver and appropriate gating. Lower frequencies ie subwoofer was measured with mic on the floor. Hope this helps
Thank you‘Reading’ an impulse response is hard. Most of us convert them into SPL vs frequency plots, CSD or BD plots. But Allen is right, learn how to measure. I’m not advocating things, but have a look here, for instance.
Thank you
Certainly you could blast over anything else with a mic 1 meter in front? Or wait for your chance in time to do a sweep. If it's more like you cant play anything loudly outside, well, that's understandable.Unfortunately outside is not very quiet for measurements.
I've taken outdoor measurements where I know a particular spike is the airplane flying overhead...
- Speaker Measurements
