Ted Weber was around for a Loong time.
Weber Speakers - Making the world a bit louder each day.
Also has a passable FAQ on whether one actually needs to recharge their Alnicos.
Typically Physical impact 'can ' demag an Alnico ie; Hammer blows or dropping from a significant height, both would result in a totally destroyed driver thou.
Also Over powering.. but that also requires melted even vaporised Voice coil power levels.. Happens, but not overly often
Great Plains Audio
Orange County Speaker
The Speaker Shop
The Speaker Shop no longer remags. He sold his machine to Great Plains Audio.
A large bass pulse could substantially demag some Alnico based woofers rather effectively, without damaging the coil. The TV25-EW in the Dyna A25 was one example that was (in)famous for this. The 4 layer coil and a magnet slug in very close proximity to it were the culprits in that particular design. It depended a lot on the individual design. I recall that there were some old JBL models that were also susceptible. Don't recall which ones.
While the speakers are Ohm Fs. They are large 4 ohm full range. 40 years old. They love 300 wpc amps... Mine is a 600 wpc amp I have had several fuse blowing events...
So I tend to believe that recharging these magnets will help...
I am also a great believer in "shaving make a pile...."
So I am going to do this, but I want to get a gauss meter too..
Johnk
Johnk
Hi-Tronics, Ottawa?
Hi-Tronics Electronics Repair and Restoration – Ottawa Speaker Repair
- Full Range
- Speaker magnet recharge service in US.
