inrank said:its just for an idea of finding out what the impedence for my Tannoy TS8 sub is so that i could use different drivers, tannoy wont give me any 'techinical' details about the amp!
Just measure it's resistance with a multi-meter, it will read about 75% of it's nominal impedance, so a 4 ohm driver will read about 3 ohms, and an 8 ohm driver will read about 6 ohms.
If you did do a sweep and plot the curve it's only going to confuse you MUCH more - as it makes it less clear really!.
