I have a Monica tube dac (16 bit, up to 192 according to philips spec sheet) and also an HT receiver that is 24/192 capable. I'd like to be able to daisy chain the SPDIF to the two of them from the same transport. I was going to install an out jack on the Monica and run a digital cable from the Monica to the receiver.
The reason for wanting this is the Monica sounds great with CD, much better than the DAC in the receiver or the built in DAC in the player, but the receiver can do full 24/96 and sounds spectacular with 24/96 music recorded from LP to DVD on my Mac. I've played the DVDs through the Monica and it works but doesn't sound good at all, almost like the timing is off.
Is it as easy as just passing the signal through, or do I need something to keep the signal clean?
SPDIF connections are point-to-point with a driver and a terminated receiver. Adding on more wire to the terminated end will just muck it up with reflected signal edges.
rfbrw has a good suggestion. add a new driver to the transport.
For the price of the transport maybe I'll just buy another one. It'll be cheaper than trying to mod what I have, an already modded Toshiba 3960.
rossl said:SPDIF connections are point-to-point with a driver and a terminated receiver.
Hence the use of build-out resistors and invention of the digital audio distribution amplifier.
zacster said:For the price of the transport maybe I'll just buy another one. It'll be cheaper than trying to mod what I have, an already modded Toshiba 3960.
I doubt you could get a DVD player for the price of a TTL chip or two.
Maybe, but the mod is never just about the part. There's the jack, the wire, and the time I'd spend figuring it out since I've never done anything digital. And then there's that special tool that you undoubtedly need to finish...😉 I think I need an excuse to get a new Oppo anyway.
- Digital Source
- SPDIF Pass through?
