If you click the square brackets in the top-right of this editor box to "remove BB code" does that help? On my machine it disables all the formatting options.
Just trying to see if there's a way to disable the rich-text editor capabilities...
@waxx Thanks for posting the video. In the video are you pressing ENTER twice at the end of each line in order to add the extra space? Then the editor takes away that extra space, right? For me, I have to press ENTER twice to get the extra space. But for me the extra line does not go away.
Send me a PM and I'll let you do a test to see if it's something in your profile.
With me it removes the problem, but also the formatting options. But the lines stay.If you click the square brackets in the top-right of this editor box to "remove BB code" does that help? On my machine it disables all the formatting options.
I do it and first it stays, but when i type further it goes away, see the video's i posted@waxx Thanks for posting the video. In the video are you pressing ENTER twice at the end of each line in order to add the extra space? Then the editor takes away that extra space, right? For me, I have to press ENTER twice to get the extra space. But for me the extra line does not go away.
If you want the formatting, it's just BBCode -- so you can still do it, you just have to mark it up, e.g.,
Produces
This is bold
https://en.wikipedia.org/wiki/BBCode
Code:
[B]This is bold[/B]
Produces
This is bold
Yes, I saw your video, but it doesn't answer the question I have. What do you mean by "I do it"? What is "it"?I do it and first it stays, but when i type further it goes away, see the video's i posted
FWIW I type, where appropriate leave a blank space to separate ideas, and when I press [enter] at the end of the next line, it jumps up because space is erased.
"Annoying" is the understatement of the year.
Ok, just in this very post it´s not happening, did you change anything?
It was doing so last night.
I don't think that Jason changed anything. Will ask. FWIW, I have not looked at it in Edge, but will now.
The above cap is from a standard, all default, test user. In Edge W10 it all worked as it should. Language packs are English and French.
- Site
- Forum Problems & Feedback
- Spacing between paragraphs in post got erased all the time
