SP3T Switch?
Hi, all,
I've just built a set of Troel's Gravesen's Illuminator Monitors, and they are amazing! Just for the sake of it, and to experiment more easily, I'm thinking of adding a switch that will allow for various levels of tweeter attenuation. Does anyone know of a single-pole three-way switch that would be suitable? I'm guessing that the Goldpoint switches, being made for line level, probably are not suitable. I can't find anything on Mouser.
Riki
Thanks for the suggestion and the kind words!
I have made enough mistakes to have learned a fair bit about veneering. It took me three attempts to get this one done. (Sadly, no, I'm not joking.) Paper-backed veneer is so much easier. I'd used that on many other projects but tried to go with raw veneer on this one. The specific veneers I tried just did not work, because they were too fragile, especially this one, which is beyond stunning, but beyond fragile. Bits would fly off when I tried to trim the edges, no matter how I did it. SO I ended up going with paper-backed sapele veneer on the sides. The front is raw veneer. I'm not sure how I got that to work.
Anyway, feel free to co-opt this thread if you want to talk veneer. Or email me at same username at gmail.
