SP-14
It will probably increase the voltage a lot. I am confident that the NOS 5y3 are very good! Totally different smoother than 5ar4...
Bronco, you only need to replace the first tube, the second tube is a buffer so rolling it makes no audible difference.
I like the new Tung sol, The n.o.s. are a little upgrade, I had a bargain buying some air force ones that are weird looking, they are nearly as good as the smoked versions, that is what I use because I had many and could find a very closed matched pair.
I was recently tempted to get into the Chinese tubes because they look well made. I don't want the Russian opaque sound or the Chinese sound.
