Sources for 3.5 mm (1/8 in) TRS jack with optical S/PDIF output
Recently I used a laptop PC (not mine) where the 3.5 mm audio headphone jack doubled as an optical S/PDIF audio transmitter. I have also seen the dual purpose headphone-S/PDIF 3.5 mm jacks on other PCs. Does anyone know if these types of jacks can be purchased somewhere?
For example the parts supplier digikey lists Toshiba part number TOTX147L(F,T) which is a 3.3V 96kHz optical S/PDIF transmitter with the "standard" optical S/PDIF cable connecter. I cannot however find optical S/PDIF transmitters in a 3.5 mm TRS jack configuration. (Nor can I find what I'm really looking for, a 3.5 mm jack serving as a "dual" output with the possibility of outputting either an electrical headphone signal or an S/PDIF optical output).
Anyone aware of any sources?
