I've built up both a pass b1 and an aikido preamp. Both currently only accept one source input. I'm looking to expand them to 2 inputs as I only either use a buffalo DAC or phono pre as sources.
My question is this: toggle vs rotary?
I don't think i really need a rotary, a simple toggle should work fine, but I'm struggling to find a high quality toggle to match other somewhat high quality components I used in the builds. (I.e. up-occ copper/silver wire, alps black beauty pots, etc), any suggestions?
I can find the quality level I want in rotary switches and may just have to go that route but wanted to run the idea by the diyaudio community first.
Thank you in advance!
I've used these with good results.They should be available in the States.
5642A9 - APEM - SWITCH, DPDT, BIASED | Farnell United Kingdom
