Source output voltages and more
I am attempting to use a non-inverting LM3875 amp with Speaker Workshop from my laptop to do some testing. I intentionally attenuated the signal at the amp's input using a 4:1 voltage divider, then to a 100k pot also configured as a voltage divider. I did this to increase the sensitivity of the pot within a small range and to keep the chip cool, as I used a small heatsink since I wanted the whole rig to be easily transportable.
The whole thing works great when a regular CD player is my source. I get around 4 watts into an 89-dB speaker (using the RS sound level meter) and the chip stays cool enough to run for hours without going into thermal protection. Today, I hooked it up to my laptop and using the line out went to calibrate it using the Eric Wallin method, specifically using a DMM to obtain 2.83V into 8 ohms resulting in 1W at 1000Hz. I never could get above .98V, however.
After double checking many things, I tried to check the voltage at the output of the line out using the DMM and the 1kHz signal. On the laptop, it was no more than .068V. I checked the output on my CD player and it was 2.5V, using a 1kHz test tone from a test CD.
My questions are:
1) Is this the correct method for determining the source output voltage, or am I presenting a load with the DMM that is too much for the laptop to handle. I assume the impedance of the DMM would be on the 100 or so kHz level, so I doubt this would cause any problem.
2) I have always heard that source output voltages are typically assumed to be around 1.5V when designing the gain for a generic DIY amplifier. Am I mistaken in this assumption? If that is a typical assumption, then should I be surprised that my CD player was outputting 2.5V? I have no reference as to the recording levels on the CD, so this could be a variable that is not correctly accounted for.
3) Since the gain of the LM3875 should typically be above 10, from what I've read here, which seems to be a result of the required Gain Bandwidth Product from the National Data Sheet, is the method of using a voltage divider ahead of the volume control attenuator a good practice? At this time, I used the RJM schematic for the non-inverting amp, so the actual gain is closer to 32. I could cut this down and reduce the drop across the voltage divider, but I think it would still be required since I am attempting to keep the output of the amp low. Is there a better suggestion for accomplishing this goal?
Thanks for reading through this long post. I thought the chip amp forum would be the most appropriate place to post, even though it is a multi-faceted question regarding source components, speaker measurement and the chip amp as well.
Thanks in advance for any help which you can provide.
Best Regards,
Sandy.
