Hi
trying my luck here (after I was not successful in the "Digital source" section): I am looking for a rubber belt for my Mark Levinson 39 CD Player. That belt is driving the CD drawer. Dimensions: 35mm circumference, 1.5mm thick, round.
ML wants $58 for the original (red) belt.
Any feedback is much appreciated.
That sounds extremely small. Just to be sure, 35mm circumference and so around 11mm diameter ?
If so then I can't find anything like that from the usual supects.
Just seen your post...
Don't get hung up on thickness and square/round section... usually if it fits it will work.
These should be available from suppliers with a 'spares' bias to their inventory. These are square...
https://cpc.farnell.com/unbranded/belt74/belt-square-35-0x1-2mm-diaxw-av7327/dp/AVBELT74?st=belts
And there is a round one in there.
Mooly, sorry for the confusion I corrected my first post to: 35mm diameter.
This source is great, I was hoping to find a source here in the U.S. but if not I will order from the UK.
Thanks!
Thanks!
There must surely be something similar where you are. These kind of spares were common in the days of TV/Video repair. Nothing on eBay?
So your looking for a round cross section belt with a cross section diameter of 1.5mm or 1/16". Circumference is 35mm and the color is red. Sounds like a hi temp silicon composition belt, not sure why it's silicon for that application.
Go straight to the McMaster Carr web sight and look for o-rings. They are cheap enough that I usually get several sizes figuring that the original is stretched.
BillWojo
BillWojo
Billwojo: Thanks will do. I am looking for a belt with 35mm diameter. So far I was only able to find 30 or 40mm belts. Both do not reliably work.
Mooly: Could not find 35mm on eBay but will check with McMaster Carr or Misumi as BillWojo and DPH suggested.
Thanks again to all.
- Analogue Source
- Source for rubber belt?
