Source for ECL86 tubes?
Hi there - I have a NZ built amplifier based on a Mullard 10-10 design. Its here -
Fountain Gemsonic - Solid State, Valve & Tube Hi-Fi
I realise that prices of tubes have sort of skyrocketed since I last tinkered with tubes. I have tried contacting these guys but havent heard back - their prices arent too bad: Vacuum Tubes - Audio Tubes - ESRC Vacuum Tubes - Electron Tubes
I have found a supplier on epay who says he can match them. Given the scarcity of these tubes now I feel I may need to buy off him - he has good feedback: ECL86 vari e STRK MEBIDX IT trksid p2055119 m1438 l2649 | eBay
OK so the epay source I cited above said he can supply four tubes - however they are from different manufacturers.
I asked him if he will match for current draw at tube amp voltages. He replied that they are tested at the makers datasheet settings.
Is this good enough?
Perhaps if I drop new pairs in and first listen for hum (to indicate one is drawing less/more current than the other), and then test the current draw of each tube - this could be OK?
Cheers
PCL86 are pretty abundant even down here - throw a 12vac transformer in to run the heaters and you can get an endless supply of PCL valves to run it for the rest of your life.
I have a 10-10 in the workshop for a rebuild and this is the path I'll probably go.
Agreed. Depending on how many O/P tube RC bias networks are present, either matched pairs or a matched quartet of bottles will be required.
The "6" V. winding in situ could be used to feed a DC heater supply for the EF86s. That would have a positive impact on the hum level.
As the OEM parts have long since literally dried out, it is a matter of routine to replace all electrolytic caps., in units of this "vintage".
It seems the unit employs SS B+ rectification. Replacing the old, noisy, diodes with quieter parts, like the UF4007 is a worthwhile, low cost, tweak.
I wouldnt mind trying this with replacement ECL86's first if I can. I am a noob with tube circuits and dont feel confident enough to make the PCL86 mod - I also heard that different manufacturers might require different heater voltages to run the PCL's. So, hmmmmm, maybe I will think about this....
I have a pair of telefunkens in there at the moment - there is a hum in one channel that follows 2 of these tubes, when I swap them to the other side.
The original resistors have been replaced by a prior owner. I finished recapping the electos' today with Pansonic FC's. There is a crappy little red bridge rectifier in there currently that I was also thinking could be upgraded.
So would I be OK to purchase a matched quad/2 matched pairs from the ebay seller - based on his decription of matching method?
thanks
Tubes are high voltage/low current depletion mode devices. You work with them much in the way you work with a DN2540.
All Pxn tube types, including the PCL86, are intended for use in 300 mA. series heater strings. Build a "500" mA. capable DC supply of "30" V. and current regulate it to 300 mA. using a LM317. More than 1 post is available off the WWW showing how to set a LM317 up as a current regulator. "Float" the current regulated rail and connect the PCL86 heaters, wired in series, to it. Connect the junction of the UCL86 heaters to ground via a cap., for hum/noise control.
Negative! Proper matching of tubes requires specimens from the same plant and (preferably) the same production run, as a starting point. Then, careful measurements of transconductance (gm) and cathode current, under real world conditions, are made. Specimens whose measurements are quite close constitute a pair ...
Thanks Eli - if I cant get the right price for ECL's - then I will make this conversion.....
the circuit diagram
