Hi, I have two Fiio hi-res players and cd player (sony not hi-tec player). I connect them amplifier, Fiio's flac performance not good as cd player. Perhaps, it's empedance problem. I don't know. Do you have any idea about the problem? Do you advice any solution?
I believe you have to switch from headphone out function to line out function.
"1 x 3.5mm headphone/line output. A single-ended output that suits all basic needs, it can be switched to line-out function in case you want to connect an external amp to the M6."
- Source difference
