Soundtream RUB1.2500D
Anyone know what transistors usually fail on this driverboard??
They all test good but as soon as i install it in the amp the amp will start drawing excessive current..
Outputs are brand new so i know thats not an issue also everything on the main board tests fine..
got this amp back with a blown power supply..
replaced the power supply fets now i have a strange issue with it..
Theres is 1.22 volts meaured directly across the speaker terminals..
If i wiggle the RCA jacks around the voltage on the speaker terminals pulse's i can get all the way up to 16 volts the it drops back down to 1.22 volts by wiggeling the rca jacks.. Any ideas?
