Hello, I need help for a soundstream xxx6500.
It works fine until five days ago.
When amp was on, it stopped sound, it isn't in protect mode, I have green led, but it doesn't sound.
I see the input of the dlm4000, input signal is ok, but it doesn't oscillate.
Ir2113 and cd4001 are new, after changed the two components it oscillate for 1 second when power on, but after 1 second I have no square wave.
Does anyone have experience of these amp?
Thank you
Thank you
It appears that there are some problems. If you don't have the schematic diagram for the amp, email me. It doesn't have the diagram for the audio board but it has everything else.
babin_perry@yahoo.com
I have an xxx6500 in perfect working order, my friend give it to me for test.
i have this voltages in driver board referred to driver board ground
with rca and when amp sounds or without rca but in master mode and amp has 49 khz oscillation in output transistor (tested from gate to source of low side)
1 in
2 ground
3 15,0v
4 14,2v
5 0
6 -14.2v
7 0
8 -119v
9 -105v
10 -112v
11 -119v
12 -00.1v
13 6.9v
14 -101v
if I put the switch in slave mode I have this voltages and amp doesn't oscillate
1 in
2 ground
3 15,0v
4 14,2v
5 0
6 -14.2v
7 0
8 -119v
9 -105v
10 -119v (change)
11 -119v
12 -00.1v
13 0 (change)
14 -101v
1 in
2 ground
3 15,0v
4 14,2v
5 0
6 -14.2v
7 0
8 -119v
9 -105v
10 -112v
11 -119v
12 -00.1v
13 6.9v
14 -101v
1 in
2 ground
3 15,0v
4 14,2v
5 0
6 -14.2v
7 0
8 -119v
9 -105v
10 -119v (change)
11 -119v
12 -00.1v
13 0 (change)
14 -101v
- General Interest
- Car Audio
- Soundstream xxx6500 no sound
