Soundstream Rubicon 1.2500 in protect
After pin 6 on the driver board drops to near 0v, do you see rail to rail oscillation on the output transistors? The oscillation will be on leg 3 of half of them and leg 2 of the other half. You may have to drive an audio signal into it to make it oscillate.
Set the scope to 5us and 50v/div. You may have to adjust the trigger level to get it to lock on the waveform.
If you do see oscillation, do you have audio on pin 1 of the audio driver board?
