Soundstream Reference 500 Driver Board
Hi guys, does anyone have a driver board for a Soundstream Reference 500 they would like to sell? I’ve replaced most of the active components and repaired several broken traces but the board still won’t work. I’ve done some extensive repairs to the main board and got the amp working, but one channel won’t produce sound. I swapped the driver boards from one side to the other and the previous non-working channel now plays fine so I know it’s the board. Thanks.
I’ve replaced most of the transistors on the board, ohm’d all the resistors and checked the diode on the board. Found several broken vias from a previous repair and repaired them but still no go. I’m beginning to believe a couple of the replacement transistors might be fakes. I bought them off eBay because I couldn’t find them anywhere else. ☹️
