soundstream pca1000D
I have a Soundstream pca1000d monoblock amp in for repair. It powers up and the protect light goes off after about 5 seconds. the amp seems to be stable, outputs are all sharing the voltage properly. when applying audio there is no output. I replaced 2 swollen capacitors and removed the stand off board or driver board and verified it for bad components. does anyone have a schematic or have seen this issue with this type of amp.
here are the pics
I swapped out the jrc 072d with a tl072 and this had no impact. not sure if I am troubleshooting using this method is correct. that high frequency signal on pin 5 goes away if I set the phase switch to 0 vs 180. if I apply a 100hz signal on the pin 5 of that ic103. it will produce high voltage on speaker output. any ideas?
Soundstream Tarantula TR880/2
Does anyone now the drive resistors for this amp it is using IRF3205 FETS. all the resistors are burnt and I can only make out the first color which is red and last one is gold. I am guessing 20 something ohms.
