Soundstream L1.2100d
Hi all
Can anybody tell me what is U20? I tried tl072 but it blowing the outputs. Pin 5 connected straight to the 3rd pin of connecter J8. As I touch that wire the frequency changes alot blowing outputs.
This sounds like U2C on the SLA1500 diagram. It may not be the exact same package but it's doing the same thing.
Do you know for a fact that you can touch the equivalent pins on other amps of the same type without causing problems?
Audio isn't likely to be coupled through a small ceramic cap, especially for a bass amp. Are you sure that you're following the circuit correctly?
