Soundstream DTR1.1400D
Someone hooked the remote wire into the negative speaker terminal by accident
I pulled the driverboard and outputs amp is still in protection mode .
1 of the 5 volt regulators has the correct voltages but the outlet one there is no voltage on any of its pins .
Any ideas on what to check ?
I think the amp blew my power supply .
My bench supply is putting out 20 volts now .
Does this sound like a regulator went bad in my
Power supply or any ideas on what to check since it’s not putting out 13 volts the voltage coming out of it is 20 volts now
