SoundMagus X3500 output driver IC
Hi there guys,
Does anybody know the replacement IC for the output PWM of this driver board?
In an other post I saw this IC could be a 45ccdkk. Which I can't get from my suppliers and seems to be a pretty unknown IC according to google.
Does anybody has a good alternative or know the correct IC type?
This is the output PWM which is going to the optocoupler board.
I changed all the drive transistors between the Optocoupler board and the PWM driver board. The components on the pwm driver board read normal. So I suspect the IC to be defect.
