SoundDitigtal 400.4d EVO chip identification
I cant identify these 4 chip.
Any help will be appreciated.
Have you tried contacting the manufacturer to see if they could/would help?
They are likely something like the following FET. I am, in no way, saying that these are the FET you have. It's just the package style (from what I can tell from the photos).
https://www.infineon.com/dgdl/Infin...N.pdf?fileId=8ac78c8c7bb971ed017bb9a9887300a4
Is the driver IC defaced as well?
ultra:​
The gate resistors are 22 in the photo.
Are the CSD used in some of the amps you see?
@ultra is correct on the mosfet and the SG3525. I have also found out that sometimes when the power supply fets blow, you may also have a problem with the outputs. I would also suggest checking the buffer transistors. They do go faulty when the 3525 shorts out. After you have replaced all faulty components and if you power up and the power supply fets get hot I would suggest you replace the output ICS
Reactions: ultra
