Soundcraftsmen MA-5002a
Hello...
I have a Souncraftsmen MA 5002a (with led output power meters, not analog).
Now it seems that the output transistor has burn
Does one of you guys happen to know what could be the transistors type?
I've found that RA 7502 uses MM4003 (substitute would be 2N5415)...
Could it possibly be the same one for a bit smaller AMP of mine?
Thank you
