Soundcraft Spirit PSU
As far as I remember the mid contact is ground, the outer contacts are AC. The Spirits run on a dual AC supply, not sure about the voltage, maybe 2x15 or 2x18 VAC. if you want a more solid connection I would fit an XLR connector to a 3-wire cable.
