I know Bybee, a wirewound Mil resistor wrapped in some material.So the only proof for your extraordinary claims is your experience? Look up the bybee discussion, I think Sy took one apart and measured it, its snake oil. Dosnt change anything, just like the wires tested in the video. You claim to be a technician but believe in voodo, you cant do both.
Bybee doing big storytelling around this device, agree.
Because they can not sell it if they say the same thing as me.
That they actually do not know what gives the good sound signature. But supplying good sound via a single component without it being measurable is not unthinkable, is my experience.
I do not see it as voodo but something very many have experienced, professional amature Diy consumer.
But as an electronics technician i must say that there is a lack of theory and measurement and I can say that with certainty because I am a technician.
As you can see here Jorma Prime Audio Cable | Jorma Design Jorma has used Bybee in their cables. I've heard these cables, they're really good, maybe partly because of Bybee
Personally, I have good experiences with putting a particularly well-sounding resistor as series resistor in shunt volume, I know some manufacturers do that too, But no one knows 100% how the good sound arises, everything is based on listening experience.
Do,you know what a resistors temp and voltage coefficient are? Dosnt sound like it.
Believing snake oil sales pitches (every overpriced cable) dosnt make it true. There's more people who believe the earth is flat, or vaccines give you autism then there are people who think silver sounds different than copper.
Jorma prime are snake oil. Why would you need different wire for biwiring than biamping? Pure BS. When you heard them did you do a blind comparison with zip cord? Than saying they sounded good means nothing.
.... experiences with putting a particularly well-sounding resistor ....
Hearing differences between resistor types could happen happen if the node it is attached to is so unstable that different parasitics of different resistors are enough to influence the oscillation you take as sound signature.
There are plenty of doctors who mess things up with patient. Have you ever heard of medical malpractice insurance? Just because someone is an electronics technician, it doesn't mean he is infallible to usual human flaws. Unless you have done a double blind listening test of cables, you should be a bit reserved on concluding what Ethan Winer's Null test is.But as an electronics technician i must say that there is a lack of theory and measurement and I can say that with certainty because I am a technician.
It does but the issue is whether it's audible or not.Presumably every tiny thing must have a sound signature,
What measurement did you do? Semper Fi told a different story in Resistors thread.Hearing differences between resistor types could happen happen if the node it is attached to is so unstable that different parasitics of different resistors are enough to influence the oscillation you take as sound signature.
Cable differences.
For example with analog interconnect cables between pre and amp -
The closer the preamps output is to a very low resistance and the amps input is a quite high impedance, the less likely the cable is to be able to have an effect.
(IE: pre 20 ohms and amp 25K ohms)
IMHO: The design of the system matters. Well designed equipment just works better. And no, high price does not equate to best design.
Greg
Greg
I would call that the nature of internet forums.I thought that was the nature of sound? 🙂
Myself, and no doubt many others, agree with everything you have shared in this thread but please realise: you are wasting your time here. The army of idle, clueless trolls will drain all your energy and drown your thread with noise. There is just no point persisting, other venues are a lot more suitable for such discussions.
The issue appears to be one group of audiophiles believes musical instruments and equipment to reproduce the sound of a musical instrument is one and the same thing.
Helpful tip for you and thor2, good way to save time is to back up the claim with evidence.you are wasting your time here.
There sure are audio related venues which the use of evidence isn't popular. One member there uses bag of pebbles taped to the interconnect cable plugs for sound improvement.There is just no point persisting, other venues are a lot more suitable for such discussions.
No. In what you quoted he says the exact same thing as me about different resitors (as all other parts) come with different parasitics.
I am adding to that that this can be enough to tune an unstable circuit node to a different oscillation or set off or stop oscillation which could be perceived as "different sound signature".
Building hi-fi is like being a chef, you have a recipe / diagram, you buy ingredients, the dish is made and tasted in the end.
Nonsense. Audio is engineering.
Jan
And that would be an incompetently designed piece of equipment, of course.
Jan
Yea try the flat earthers or the the no vaccers, there are also other places where hairbrained ideas get full support with absolutely no proof, logic, or scientific backing. There the army of idle, clueless trolls will back up every dumb idea you have.
I agree on this part. But one point he clearly made is that one resistor he measured act as a high pass filter with a 10kHz corner frequency, no need to go into node stability or oscillation at all. 20 years ago, that resistor would be audibly muddy to me, even used on a passive attenuation network, no relation to stability.No. In what you quoted he says the exact same thing as me about different resitors (as all other parts) come with different parasitics.
- General Interest
- Everything Else
- Sound signature
