And there you have a perfect linkage to the Power Supply Reservoir thread. Apparently Magnepans are almost pure resistive loads over the whole audio band, meaning they fit the simulation load scenarios almost perfectly. "Real", other, speakers have all sorts of peculiarities along the frequency range, just enough to throw lots of amplifiers into a misbehaving "tizz" as they attempt to feed the speaker crossovers, etc, with the required current spikes ... 🙂Sorry that the conversation has already moved on but I've been meaning to say that I share your appreciation of Harman Kardon and Luxman. I have several of each (receiver/amps) that I have purchased Used, from the late 1970s or early 80s, mostly, and am always amazed at how good they sound. Incredibly good, really. Even the little 50-watters seem to drive the 4-Ohm Maggies perfectly. (Actually, even a 30-Watt Adcom drives them almost as well as my biggest power amp, which is rated to do 1000 Watts into 1 Ohm, average, continuously.)
Frank
Whats with the PM ...🙂
This is about what I feel as well, Tom. Having been in this for 42 years now, if anything, I can safely claim to be with experience. And it teaches me that at each and every turn, HK equipment was always more or less at the top of the mass produced products, and sometimes, it was THE pinnacle of the day for a while.
Not perfect of course, they actually have some faults built in. When designing the mechanicals, I think they send their purchasing department out with a mission: find the cheapest and worst pots and rim pots out there, and then buy the even cheaper ones. "Poor quality" doesn't even begin to describe it, believe me.
Until about two months ago, I considered the HK 6550 integrated amp a good one, but not really exciting. Then, I set about refreshing it, i.e. pulling out old capacitors and putting in new ones, it's been with me for exactly 20 years. And in the process, I decided to exchange the installed volume pot with an Alps Blue, which I had at hand, so zero hassle. I did so, and I stood there fklabbergasted - in fact, I still have difficulty in believeing what I hear.
Just that one pot, and I note that my Tone Defeat switch is always ON, in one step took it like five classes up. From zero to hero in one easy step - it CAN be done. To cut a long story short, it now does everything it did before, but with so much space, air and spatial detail that it wipes the floor even with the Karan, which is a very serious player. It is easy to hear on a good recording that the violinits is to the right and a bit above the say trumpet player. And two months down the road, I still find it hard to believe that so much can be obtained from such a device (given its price range) and with such a small change.
Truly, EVERYTHING matters. I believe now.
Luxman - of course, I have known about them for over 30 years, but my practical hands-on experience has been almost nil. I never owned one of their products, until this C-03 preamp. And frankly, I just love it, it is almost exactly what I would want in a perfect (for me) preamp. Even now, in its "as is" form, i.e. before refreshing the caps. As you would eexpect, I do have a few quibbles, but none of paramount importance.
I am now in the final stages of refreshing my Marantz 3250 B preamp, and I just can't wait to pit it against the Luxman. I think the Luxman will come out better, but then it did cost a fair amount more than the Marantz, relatively speaking.
And, in closing, I freely admit that Harman's think has influenced me more than any other approach or philosophy out there (yes, I did read Bob Cordell's and Ben Duncan's books on amps). Never worked for them, as some lucky guys here did, but I obviously do have some sort of a bond with them. Maybe because I had to wait for some 16 or 17 years before I bought my first H/K - every time I wanted to, something came up which was more urgent, and so it went for years.
Read and learn, old son. 😀 😀 😀
Seriously though, you're right, I did respond and that will be that, for more we will switch over to PM. At your loss. 😎
Frank
Agreed.
Mostly because my own speakers are not unlike the Magnepans in this respect, an almost pure resistive load. Nomnally 8 Ohms, minimum 6.5 Ohms, maximum 11 Ohms. Worst case phase shift -25 degrees.
Literally ANYTHING can drive them, including the highly suspicious low, low end. Frank's chip amps would have a field day with them. My humble Toshiba 45 integrated amp, even in its present unrefreshed form, sounds good with them; try it with the AR 94s, and it quickly gets into trouble as the volume goes up. Given its teeny weeny power transformer, no wonder.
I remember a British speaker of some 20 years ago or so, I forgot which, with the most complex crossover network I ever saw, which was tested in a Brit mag. It was given a thumbs up grade, with an explanation that a good part of that XO was dedicated to making the speaker an even and mostly purely resistive load, so its lowish efficiency, demanding more work from the driving amp, was no real problem at all.
I think even the efficiency issue takes a definite back seat to what kind of a load is presented to the amp. The more resistive the load is, the less important the efficiency becomes.
Kef 104/2, with conjugate load matching, perhaps?I remember a British speaker of some 20 years ago or so, I forgot which, with the most complex crossover network I ever saw, which was tested in a Brit mag. It was given a thumbs up grade, with an explanation that a good part of that XO was dedicated to making the speaker an even and mostly purely resistive load, so its lowish efficiency, demanding more work from the driving amp, was no real problem at all
As regards pot's, in my book these are evil; I can always hear the degradation they cause ...
Frank
Frank
I don't think so, Frank, I think it was an exotic brand with a very exotic price. A pretty small monitor speaker, but with very, very good measurements overall.
Hi fi is time distortion . If my mood changes so does the sound which further complicates it . I am lucky , I can usually change my mood by listening . There are unsubtle time differences called room effects . Hearing music out of time period transports us back . Thus it is all fiction . What I think we observe easily is lack of frequency range and dynamics . Additional distortion stops the subtle realities working at all . Digital is neither wrong nor right . It is a layer of complexity which we seem for other reasons to need . Digital is almost like being forced to learn English to get on in the world .
Thus time distortion is where it is in doubt . To have a recording of Beethoven before big fi would be wonderful . I think Previn said of Furtwangler , if we tried to convince him of " real music " he would say " Beethoven would have preferred it as it is now " . The point is big orchestras have large time distortion . They can not keep up a fast rhythm due to time delay . A conductor is required to make it work . A great conductor makes the building work . Thus real music has the same problems . We add to it .
@Frank
In my book, pots are quite simply necessary. Therefore, neither evil nor good. As with any other component, I will always strive to use the best I can get my hands on, or afford, whichever comes first.
Do they distort? I would imagine so. But I cannot control the volume or balance without them, be they mechanical or electronic. So, all I can do is try to reduce their distortion to the least possible value.
@Nigel
I consider myself as a very lucky man to be able to influence my own (sometimes filthy)mood by playing appropriate music. I have music for most of my moods. When I'm tired and fed up, I put on Enya to get me back on the track. If it's raining outside and the weather i foul, I put on Katarina and the Waves "Walkin' On Sunshaine", that never fails to cheer me up, a true summer song if there ever was one. If I'm in a pensive mood, Chris Isaac usually makes me pause and question myself. Poetic feelings are usually taken care of by Loreena McKennit. Rebellious is well served by Bob Dylan, Joan Baez, Barry McGuire and the late 60ies-early 70ies protest gang. Leonard Cohen and Gordon Lightfoot never fail no matter what. And so forth.
The day music stops influencing me is the days I sell of everything, buy a late 70ies receiver and call it a day.
@Nigel
Not what was meant, when Tom mentioned 1ohm , it was like sending me a PM ..🙂
As far as underrated components , Onkyo , i would put them up against HK , i will never forget my big technics receiver coming pretty close to matching My ML-9 for sonics , has tainted my views on Levinson amplfiers ever
Since ....🙂
ML did make excellent pre-amps thou....😎
Similar type of music, yes, but not in Enya's league by a long shot.
There can be only one (Enya)!
Funny thing is she is sometimes seen as having created a career for Enya by being first . Some of Enya is great recording .
I have valves that listened to this being recorded .
Fairground Attraction - A Smile In A Whisper - YouTube
Roy Gandy ( Rega ) introduced me to this singer .
http://www.youtube.com/watch?v=zMGywGqf7wI
Bless them both then, but Enya is the one for me. You take the sister.😀 😀 😀
Not quite. So far I've found the electronic variety fine, because the inherent contacts don't degrade with time. I can literally hear the quality of the contact of mechanical items start to "go off" soon after the contact surface has been refreshed; electronic units don't suffer from this characteristic.@Frank
And there are other alternatives: hard wiring, transformer coupling, LED based attenuators. For me, there is a certain quality level I'm always after, it is literally like reaching the top of a hill, and almost all other systems I listen to are still huffing and puffing on the uphill grind. Once that peak is achieved, everything better again is just gravy -- I fervently believe that audio can be absolutely astounding, better than the "real thing" by a good margin -- if all the stops are pulled out ...
Nice thoughts ... 🙂The day music stops influencing me is the days I sell of everything, buy a late 70ies receiver and call it a day.
Frank
Actually, senhor Frank, you should explore your own garden before blasting pots.
As a matter of fact, I happen to own two different models of discrete resistor pots, both from Australia. One I bought, the other I got as a gift. Now, I have not fully employed them yet, both are slated for respective projects, but as you might imagine, my curiosity got the better of me and I couldn't resist rewiring the little Toshiba (152% budget model) so one of those two pots acted as its volume pot.
As you might imagine, the difference was immediately obvious and, well, sizeable. A completely new deal. More like something else altogether. That's as far as I got at the time.
I must add that I am also very happy with Alps Blue pots - they are much better than your El Cheapo variety, at a price, but a price I am willing to pay for the added sonic quality anytime.
Discrete resistor versions should work better, but I come from the angle that every non gas-tight connection is a bad connection. Once you experience a system where every deficient contact is excluded you can never go back, the signature of the type of distortion that can occur is too distinct.Actually, senhor Frank, you should explore your own garden before blasting pots.
The key difference is that "bad" recordings lose their smell on a totally clean setup -- to be able to run old, poor recording technology albums at deafening volumes, in total comfort is something to treasure ...
Frank
Talking music . Anyone love Julie London ? This is a later recording .
Julie London-My Funny Valentine(1981) - YouTube
@fas42
The problem I experienced with electronic tone control ICs was enough to convince me to forget them and leave them for TV and such like, where sound quality is not really very important.
True, that was over 20 years ago, it stands to reason they have been improved much over that time, so I'll have another look.
- Member Areas
- The Lounge
- Sound Quality Vs. Measurements
