Sound domes
A friend of mine has a handicapped child. To help the kid enjoy his music without disturbing others, he was looking for something like this:
Have handicapped kids less rights disturbiung others while einjoying their music ? 🙁
Back to on-topic: With the ones that I heard so far you can't talk of enjoying music. The sound was like telphone quality.
I'd raher suggest either headphones or something that is meant for listening in the closefield.
Narrow-beam radiation can also be done with arrays of small drivers if needed.
The electrostatic solution looks good (apart from the LF reproduction) but I guess it might be quite expensive.
Charles
We used that principle on an exhibition stand for EA games a good few years ago, only we had to get, (very expensive), custom made acrylic domes made. All you need is a parabolic section, I wonder if you could make something up using an old umbrella covered in paper mache or plaster impregnated bandages?
I wonder if a couple of cases of plastic drinking straws stacked in front of the speakers would make them directional. leave the cardboard sides to hold the straws together, but remove top and bottom and stack on side to direct the sound forward only....
Use a small satellite dish or a large mixing bowl. Very cheap reflectors.
A very small driver in a little box at the focal point would provide quite directional sound.
The dish/ bowl could be painted with patterns, or white with one of those little motorized lamps shining on it.
Remember bass is less directional, you may need to filter out the low frequencies to reduce the disturbance to others.
