sound card test
Using a notch filter will help. Apart from that one of the main reasons I had for switching from using a soundcard with REW or Arta was the convenience of not having to deal with calibration and setup issues. Some people complain about missing asio support and being bound to the manufacturers software. To me it's actually a plus but to each their own.
APx555 -you said cost no object. . .
Actually there are a lot of details that influence a selection.
First what is it for? Music recording? Or playback? Measurements?
How many channels?
What interface. ISA?? PCI, PCIE, Firewire, USB, Ethernet?
The answers are not simple or obvious.
I am using a steinberg UR22C, 192kHz and 24bit full duplex, and the noise floor is very low . The software I use can do averaging and that gives very smooth and clean graphs. Agree to the comment that you should somewhat protect the Inputs and outputs - Just had to buy a new one 😀
It uses a nonstandard hardware USB interface. It's all published open source. An ASIO interface was created for the QA401 but it used different USB hardware. Could be done for the QA403. But not on their current roadmap. Lots more at their forum.
It is on you to limit input levels accordingly.
Not that show-stopper imho.
That's a total show stopper for me. Things do go wrong on the testbench, no matter how hard I try to avoid them. Otherwise there would be no need for a testbench.
I absolutely need a workshop/testbench tool, not an audio production machine. It it goes down to -120 dB distortion or better, fine. If not, fine.
My RTX6001 is just perfect for my needs. It has switchable and accurate (calibrated) voltage levels. It works with any software designed around sound cards, so it can be used for pretty much any type of electronic and acoustic measurements (sources, amps, loudspeakers, etc.). And it just smiles at you if it accidentally gets a dose of tube-amp high voltage to its inputs...
JCAT
sound card​
